Bronco II Ford Bronco II
poor gas mileage
Old Dec 3, 2006 | 06:56 PM
87broncoll's Avatar
87broncoll
poor gas mileage
im only getting about 10 miles to the gallon on my 87 bronco 2 4x4.Just had a major tune up and cat converter done among other things.Im also having to push it hard on the highway before it "catches." what on earth could cause this? could a vacuum leak cause that as well?
Old Dec 5, 2006 | 11:31 PM
87broncoll's Avatar
87broncoll
I do not smell gas.All i smell is oil from the leaking valve cover gasket.The truck WAS running rich but after $1300 of work thats been fixed, so no smoke at all.I do know it needs an air idle.How would i check the regulator? Injectors? How much am i looking at to replace these?Im so frustrated, what started as a good deal has already cost me 2k and its still needs work! Please help.
Old Dec 8, 2006 | 06:52 PM
HappyJack's Avatar
HappyJack
What size tires and gear ratio are you running? Is your speedo correct?
Old Dec 12, 2006 | 05:06 PM
Widall's Avatar
Widall
If you have not already done so check to make certain that the engine temperature is correct. Mine was burning a lot of gas because it was running too cold, changing the thermostat helped a lot.
Bill420
New Member Introductions
Mar 19, 2007 04:09 PM
87broncoll
Bronco II
Dec 6, 2006 10:13 AM
SuperDutyF250
Computer Chips & Tuners
Mar 3, 2006 07:57 AM
ATC_250SX
Apr 19, 2004 09:07 PM
