Where does wiring split?
Old Dec 3, 2006 | 06:39 PM
Claybe's Avatar
Claybe
There is no power getting to the right side (green wire) of the trailer wiring harness before it goes through the firewall. I tested the white/lgt blue wire out of the turn signal and it is fine, but apparently the wires split somewhere under the dash for the trailer harness. Does anyone know where or how they split? I am losing power somewhere under the dash to the green wire and I don't know where to start. Thanks for any help (a nice wiring diagram would help!!!!)!!! Clay
Old Dec 3, 2006 | 07:23 PM
subford's Avatar
subford
The white/lgt blue wire has nothing to do with the trailer right turn lamps.
It leaves the turn switch as a orange/lgt blue and goes through the firewall (C202) and comes back in through the firewall (C205) and goes back out of the firewall (C202 again) to the engine compartment fuse box. Goes through fuse F a 5 amp fuse (bad fuse?) changes color to dark green and then goes through connectors C202, C205, C207 and to C217 (trailer plug).
Old Dec 3, 2006 | 07:41 PM
subford's Avatar
subford
Here is a diagram:
http://i54.photobucket.com/albums/g9...railerTurn.gif
Old Dec 3, 2006 | 08:04 PM
Claybe's Avatar
Claybe
Subford,
You are the MAN! Thanks for the explanation!!! I went and checked the fuses under the hood and that was it! I didn't know that is what those were for. Thanks for the reply and the help - I really appreciate it!
