Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Headlight Upgrade
Old Dec 3, 2006 | 02:54 PM
79Thunder's Avatar
79Thunder
Headlight Upgrade
Hi guys, can anyone tell me if the headlights (the whole assembly)
from a late model '05-07 can be installed in an older '01-'04 escape??
The mounting brackets all look the same, but I'd thought I'd ask here first in case someone here has already done it.
Thanks.
Old Jan 20, 2007 | 05:38 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
....bump....
Old Jan 22, 2007 | 11:29 AM
tcesni's Avatar
tcesni
If you dont' get an answer here, you might call the Ford dealer or a body shop and see if the part numbers are the same. My guess it that they are identical
Old Jan 22, 2007 | 12:26 PM
ove1's Avatar
ove1
I've seen reports of the headlamp retrofits. It appears that the mounting is the same, but that the wiring is different. With separate high and low beam lamps on the newer units, that would seem a given.
