Fuel Filter## Same or not ?
Old Dec 3, 2006 | 12:26 PM
compsec's Avatar
compsec
|Just went to renew my fuel filter for the first time on 4.6 screw (2004) but when looked appears to have pretty fancy hose ends fitted in the factory.
At a risk of breaking them I left, it is there a trick to getting the hoses off each end ? The replacement Fram unit I have just has steel straight ends.
Old Dec 3, 2006 | 01:32 PM
wildcard30's Avatar
wildcard30
Here's a great thread that shows how to R&R you 04-06 fuel filter...
It has pictures and instructions...
Changing your Fuel Filter
Old Dec 3, 2006 | 05:18 PM
04 FX4 Lineman's Avatar
04 FX4 Lineman
Takes a special tool to release the hose oon each end. Is a bit of a trickthe first time until you see how they release.
Old Dec 3, 2006 | 06:34 PM
HomerWinzlow's Avatar
HomerWinzlow
On some vehicles there is a green tab that must be depressed and then pull the fitting back on the side to the fuel tank. Its real easy to break and requires a complete set of lines to the rear to repair. Very costly mistake.
