clutch master cylinder help
Old Dec 3, 2006 | 05:37 AM
willow72's Avatar
willow72
i have a 1990 f15o with a 5 speed o/d and lately the clutch seems to be getting closer to the floor and harder to shift i dont know much about manual trannys but from reading on this board it sounds like i have master/slave cylinder problems how hard is it to replace these or how much does it cost tohave it done where can i get insructions how to do it thanks in advance you guys are always a big help john
Old Dec 3, 2006 | 01:48 PM
385seriesHemi's Avatar
385seriesHemi
It could be your clutch master cylinder or your slave cylinder or the Fingers are worn down alot on the pressure plate assembly where the throwout bearing rides when you apply pressure with clutch fork. check for leaks in the clutch system, check free play also because too much free play will cause dragging and hard shifting.
