Airbag Minimum PSI?
Airbag Minimum PSI?
On my Ride-Rites (Firestone), the manual recommends keeping 5 psi in the airbags when not towing to "prevent damage" to the bags. BUT...I've found that with 5 LBS. left in the bags the ride is much stiffer than usual. And since the truck rides pretty stiff to begin with, I really don't appreciate the stiffer ride. So, I've been leaving 0 PSI in the bags when not towing.
Anyone else doing this with their airbags?
Also, where are you guys mounting your remote "Air Commands" in your Super Dutys?
Thanks.
Thanks.
Toy3zve,
As BlueOvalBoy said, you need to keep the recommended minimum amount of air in the air bags or they will fail prematurely. If the ride is to rough with 5psi in the air bags (this is a truck BTW) then you would be better off to air down your rear tires a little when running empty, than running no air in the air bags. Just remember to air your tires back up to proper pressure for any load or trailer you are towing.
Hope this helps
Hope this helps
Originally Posted by cangim
Thats odd, with 5 psi in each bag on mine, I think it rides a little bit better. At anyrate, I put my controls in the glove box.
OK by me, if I wanted a smooth ride I would shackle it.. or buy a 1/2 ton... hee hee Not
give me heavy leafs..Break out the big lumber.
Peace
Thanks.
Thanks.
