1994 Power Window No Go
Okay Okay--enough blowing off. My power windows aren't working. Yes I have changed out the fuse (20A) fuse position 14 from under the dash. I also checked to see if the basics were at fault. I swaped out the power switches from the door panels No Go. I have checked the motors-I ran straight electricity to them-they work that way. I checked all of the wire that go from the switches on the doors to the Master Window door lock switch which is the main block in the Drivers door. Question. Is there something I'm missing-Like where the wires run just through the door and into back into the body? Is there possibly another fuse or module that is keeping my windows from working to the switches? It just aggrevates me to no end that BOTH windows don't work. I see from the schematic where the Driver side door panel is the master area. Any advice anyone might have woul dbe greatly appreciated. Except for this problem it is bullet proof and this is my second van I have saved from the grave. It's 4.0 is terrific. I will never drive anything else other than my "COUCH MOBILE!"-Boz
