Need help with Climate control
Old Dec 2, 2006 | 03:11 PM
BHE's Avatar
BHE
I have 96 f 150 and the air, Heater and defrost has been working just finer until a couple months ago. while working the air would quite flowingout the vents but you could her the motor turning either on high or low. Now when you turnt he cliamte control you get very little air out and then it just stops blowing but the blower fan is stillworking. ANY SUGGESTIONS> It is very cold now.
Old Dec 2, 2006 | 03:45 PM
quicklook2's Avatar
quicklook2
stuck door or vacuum leak on the line that works the doors.
Old Dec 2, 2006 | 04:55 PM
BHE's Avatar
BHE
Where is the door located at so i can check it out.
Thank you
Old Dec 2, 2006 | 05:02 PM
wrenchturner's Avatar
wrenchturner
it is hard to access. I took my glove box out. used a dremel and cut out a panel, from in there you can see the A/C door open it and then you see the blend door. If you need I could send pics.
Old Dec 2, 2006 | 05:32 PM
quicklook2's Avatar
quicklook2
listen for leaks in the hose first open hood and find line, than take out glovebox and follow line.
do what wrenchturner says next.
go back two weeks in this forum for more posts on same problem.
Old Dec 2, 2006 | 08:56 PM
wrenchturner
i agree eliminate simpler things first. you can see if you look up under the passenger side dash to see if the arms are moving the doors. mine did, but the door was blocked by a piece of dowel rod that fell down the defrost vent.
Old Dec 3, 2006 | 07:25 AM
BHE's Avatar
BHE
It could also be gummed up due to soda's and coffe spilling contantly off the dash either from me or my kid. Also the darn thing worked last night and this morning. HMM I will check th vaccum and then the box behind the golve.
Thanks for the info
BHE
