Sponsored by: Real Truck
odd cluster/tail light issue.
Old Dec 1, 2006 | 10:03 PM
ReAX's Avatar
ReAX
Last night everything was fine. Tonight I left work, turned my headlights to on and took off. As it got a little darker I noticed I don't have any lights on in the cluster. I rolled the dimmer up and down, then flipped over to auto. On auto my cluster lit up properly. I turn it back to on and continue on. When I got to my first stop, I left the motor running and lights on. I checked my head and tail lights to see if I have any other problems. No tail lights. So I turn the switch to auto. Tails and cluster light up correctly. I pulled fuses 35 and 41 both were good.
I am suspecting my headlight switch, but in the day light I will be going over all of the fuses. Anyone have this before?
2002 F250 Lariat leather and loaded.
Power locks, windows, pedals work. Door switches illuminate in either postion.
Old Dec 2, 2006 | 06:15 AM
ryaneverk2's Avatar
ryaneverk2
I think you're on the right track suspecting the headlight switch, since it was effecting the instrument panel and taillights as you described. I wouldn't think it'd be a fuse, since you said you had no tails when you had the switch on, but then the tails came on when you switched to auto... I think the switch is the issue.
Let us know what you find.
Old Dec 2, 2006 | 11:40 AM
ReAX's Avatar
ReAX
It was a connection for the remote start on the back of the headlight switch. Odd that a three year old splice would give up the ghost overnight, with no signs.
Old Dec 2, 2006 | 04:15 PM
ryaneverk2's Avatar
ryaneverk2
Was the splice with a little crimp connector or soldered?
Old Dec 2, 2006 | 07:47 PM
ReAX's Avatar
ReAX
butt splice. I replaced it with a shrink and solder butt splice.
