Tire Size
Old Dec 1, 2006 | 07:01 PM
Night Bird's Avatar
Night Bird
Tire Size
What is the largest tire that will fit for a stock height truck. I am going to be getting a set of 16x10 wheels and need new rubber on them.
Old Dec 1, 2006 | 11:34 PM
Monsta's Avatar
Monsta
Sit. Stay.
305s (depending on brand) rub a bit at full lock...from what I hear. I think you may be safe with those. 295s are a good choice, too.
Old Dec 4, 2006 | 05:48 PM
Night Bird's Avatar
Night Bird
thanks, Iv got some 305x70/16's in nitto terra grappler coming in.
Old Dec 4, 2006 | 06:11 PM
quietman's Avatar
quietman
295's bare-ly rub, or maybe not...
305/70 or 315/75 (same width, pretty much) WILL rub.
I have been simply living with it. My buddy that used to run a Ford dealership would have a bead of weld put on the stops to limit travel.
Once again i had a gnarly weekend of technical off-road rock/canyon creepy-crawling places where CJ-5 drivers thought THEY could not go (and were most likely correct)....and got away with it unscathed, pretty much...
...somehow. At times I had less than an inch or so between BOTH rear windows or fenders, and drug/banged the hitch several times, and the skid plates got used. again. oh and the stupid running boards. got kids...
315/75/16 is pretty much the minimum tire for an Ex that gets used. Bigger might need relief from the front bumper, and will also rub at full lock, but might be worth it.
The Ex is pretty cool. Not an early Bronco, but pretty cool...
_____________________
Quietman
www.roenation.com
2005 EXCURSION LIMITED-options (everything) equipped Eddie Bauer edition 4X4 PSD
4" FabTech lift/level, Bilstein $$ mono-gas shocks, Rancho Steering Stabilizer
Silverstar 9005 fog and H13ST headlights + wiring mod to run high beam and fogs together,
BFG 315/75/16 AT KO's on Factory Mags, 22" front and 18" rear rain-x wipers,
LANDYOT Generation II Radius Rods, Ford factory hood insulator
