Rear Diff. Fluid Help!
Old Dec 1, 2006 | 05:54 PM
Mountianeer's Avatar
Mountianeer
I have a 96 F150 with a 302. It way past time to change my front and rear diff. fluids, but I'm not sure what type of fluids I need. Does anyone know how I can tell if I have Limited Slip or if I need extra additives. How much product sound I need to buy for each diff.
Old Dec 1, 2006 | 07:35 PM
RyanJake's Avatar
RyanJake
the specs are provided at the local AutoZone. Just get on their website and go to specifications.
Old Dec 2, 2006 | 04:19 AM
tim73's Avatar
tim73
There should be a little tag on your differential cover, with some numbers. Those numbers will tell you what kind of rear end you have. Most likely youll need 75 or 80w-90 gear oil. Your owners manual will tell you for sure.
Old Dec 2, 2006 | 05:20 AM
jeff1089's Avatar
jeff1089
AllData states:
Standard - 80w-90 GL-5
F150/4.10:1 Axle ratio & lightning pickup - synthetic 75w-140 GL-5
Limited-slip 80w-90
Note: LIMITED-SLIP OR TRACTION-LOK IDENTIFICATION: Label on door lock pillar shows letter and number
Jeff
