Sponsored by: Auxito
4x4 "problem" a breeze to fix
Old Dec 1, 2006 | 02:48 PM
preppypyro's Avatar
preppypyro
After doing a little research on here I found an easy solution to my 4x4 not shifting into 4hi. Lubed it up and it all works good. Such an easy fix it almost makes me worried!
Old Dec 1, 2006 | 05:54 PM
stick13's Avatar
stick13
What did you do to lube it up exactly?
Old Dec 1, 2006 | 06:06 PM
astone's Avatar
astone
I am curious as well as I can't shift into 4 LO right now.
Old Dec 1, 2006 | 10:12 PM
n8line1978's Avatar
n8line1978
Yeah, mine won't engage period.
Old Dec 1, 2006 | 10:50 PM
preppypyro's Avatar
preppypyro
Its easy, take the plastic/rubber piece off that covers where the vacuum hoses go into, and lube the piece that goes in and out. Worked perfectly on mine! Once you crawl under, its very easy to see what im talking about. Its located on the front axle.
Mtnhermit
Apr 30, 2016 12:57 AM
SDElwood
Oct 15, 2013 03:00 PM
greenterror
Sep 20, 2008 12:42 PM
GeneStoner
May 15, 2003 08:45 AM
