99 explorer running problem
Old Nov 30, 2006 | 08:03 PM
jasonholmes76's Avatar
jasonholmes76
my wife has a 99 explorer v6 sohv it has started to not run right. when you crank the key it starts goes to about 1500rpm then dies, only does this when its cold, problem started a few weeks ago first time it got around 50 degrees. if you gunned the engine up to around 4500rpm it would then hold any idle. it warmed up and we had no problems till today it was around 20 degrees and gunning it did not work. I was thinking maybe idel air controller, but not sure. dont want to spend unnecessary fund so close to christmas. any help would be cool...
Old Nov 30, 2006 | 08:05 PM
phatpony's Avatar
phatpony
Sure sounds like the IAC to me. You could try and clean it.
Old Dec 6, 2006 | 06:26 AM
foolishone's Avatar
foolishone
Mine was the intake o rings.
Old Dec 7, 2006 | 12:45 AM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
Intake O-rings... I'd bet on it... they swell up a little and seal up when they start to warm up.
When you replace them you'll notice the replacement are about twice as thick, and the old ones are hard and brittle.
Good luck
92cruisinblue
Jun 11, 2013 09:13 PM
abeltre99
Jan 15, 2007 04:21 AM
Rick78
Dec 18, 2005 06:28 PM
narcicus
13
Mar 12, 2004 10:25 AM
71ranchero500
Jun 3, 2003 02:12 PM
