Rough Start Up!
Old Nov 30, 2006 | 06:29 PM
Mountianeer's Avatar
Mountianeer
Rough Start Up!
I Have a 96 F150 with a 302. Recently I have noticed that my start up were taking a bit longer than usual. When I turned the key it would take the starter a few or more cranks to start up the engine. Well, she's got just shy of 200,000 miles on her so I changed out the starter for a all new modle from the Advanced Auto. Now it still takes a few or more cranks to start up the engine, but the starter sounds like some futuristic machine gun. Should it take more than a 1 or 2 count to start up my 302 or is there possibly an ignition problem I haven't found. Any Insight would be awsome. By the way, once she's running she has a smooth idle, but sometimes wants to stall out when I am backing.
Last turn up was one year ago this month. Very regular maintenence and only about 1 or 2 thousand miles since, if that.
Old Dec 2, 2006 | 01:21 PM
95Ford4x4's Avatar
95Ford4x4
could be several possibilities. have you ever replaced/cleaned the injectors?? is this only when you crank it cold, or even after it's been running and engine is at operating temp??
Old Dec 2, 2006 | 02:51 PM
Mountianeer
Only when starting up. It's not bad. But compared to other vehicals I have had it is a little on the slow side. As for the fuel injectors, those I clean fairly regularly with sea foam additative and I do run a high grade of gas.
Old Dec 19, 2006 | 08:08 AM
rail's Avatar
rail
8th Gear
Hello, I had the same problem with stalling when put in reverse, Replaced TPS and all was fine....
BrandonT71
Aug 2, 2013 07:52 PM
Poor'it in'her
Sep 14, 2012 05:45 PM
Malorkis
Jun 7, 2011 01:44 AM
Malorkis
Feb 2, 2011 01:54 AM
Ed
Aerostar
Feb 15, 2006 07:00 PM
