Sponsored by: Real Truck
Suspension Noise
Old Nov 30, 2006 | 05:08 PM
Fcal's Avatar
Fcal
Suspension Noise
2005 F250 Crew Cab. When Making a slow sharp right turn over a bump, I get a rubbing/squeaking noise from the front left wheel area. No, it's not the tire rubbing. I checked out the suspension as good as I can, and can't see anything wrong. Could it possibly be the wheel bearing. As ususal, when I take it to Ford, they can't duplicate it.
Old Nov 30, 2006 | 08:57 PM
4x06's Avatar
4x06
Do you have a steering stabalizer ? cause mine was put wrong by 4wheel parts and part of the clamp of the stabalizer was rubbing when ever I make a sharp turn...which I have to correct later on...by my self.
Old Nov 30, 2006 | 09:32 PM
Stroker4Life's Avatar
Stroker4Life
More then likely its your track bar bushings or a loose track bar bolt. Get underneath your truck and grab that bar that angles up towards the drivers side of your truck. If its loose thats probably where your squeek is coming from.
