Oil Cooler Leaking
Old Nov 30, 2006 | 10:50 AM
The Grinch's Avatar
The Grinch
Oil Cooler Leaking
Tis the season... The oil cooler on my 95 is leaking like a siv. Is it a big deal to change? Does it include draining the oil and all the coolant? The Ford manual is not clear at all in regards to the process. Anyone done the seal replacement on this?
Old Nov 30, 2006 | 11:06 AM
DAN-D-DIESEL97's Avatar
DAN-D-DIESEL97
There Is Coolant In The Cooler,you Will Lose Some,wil Also Be Good Idea To Change Oil.o-rings Are Bad That Is Why Its Leaking,probably, I Have Seen Some Of The Aluminum End Castings Corrode Here In Mich Due To Salt And Crack.
Old Nov 30, 2006 | 11:12 AM
The Grinch's Avatar
The Grinch
Thanks. Is it a big deal to replace? Just pull the end off where the oil filter mounts and remove the tube and replace seals or is it more detailed?
Old Nov 30, 2006 | 11:38 AM
DAN-D-DIESEL97
Its A Little More Detailed,but There Is A Thread Somewhere On Here That Is A Very Good Guide.
Old Dec 1, 2006 | 07:26 AM
The Grinch's Avatar
The Grinch
Anyone have the thread link on fixing a leaking oil cooler?
Old Dec 3, 2006 | 11:28 AM
The Grinch's Avatar
The Grinch
Anyone had to deal with this? How about a direct link to the thread?
