Sponsored by: Real Truck
Unlock Codes or Instr
Old Nov 30, 2006 | 08:32 AM
Ford-Tough's Avatar
Ford-Tough
Question Unlock Codes or Instr
I am looking to find the factory unlock codes for the door keypad on a 2006 F-250 SD. Or if anybody has the instructions for resetting the door codes.
Old Nov 30, 2006 | 08:51 AM
tjmax7668's Avatar
tjmax7668
You need the original factory code to change it. Lock module is behind glove box, should be 5 digit # on sticker. to change it, enter original 5 digit code then hit 1, then new 5 digit code within 5 seconds. if battery goes dead will revert back to original code. hope this helps
Old Nov 30, 2006 | 09:15 AM
sgthawkusmc's Avatar
sgthawkusmc
That's just what we want everyone to have. A master key to unlock our trucks...
Old Nov 30, 2006 | 09:24 AM
DavidB's Avatar
DavidB
Cool
Unless you leave the truck unlocked, no one can get access to the code. If you leave it unlocked, what is the point. This information is not hard to obtain from a dealer. Think about it.
Old Nov 30, 2006 | 10:25 AM
EnviroCon's Avatar
EnviroCon
First, Welcome to FTE.
There are 3 ways to get the code.
1. The truck should've come with a plastic card (the size and shape of a credit card) that has the permanent code (which applies only to your keypad) and instructions for resetting the keypad. It's usually located in the case with the Owners Guide, Warranty Guide, etc.
2. On the Body Security Module (BSM, which used to be called a VSM) which is located above the tranny hump behind the dash.
3. The dealer can pull the code using their diagnostic computer.
Old Nov 30, 2006 | 02:42 PM
sgthawkusmc
I thought he was talking about a master unlock code not the one that was on the ECU. You're right...
