Check The Harness That Plugs Into The Cps, I Have Seen These Replaced And Have The Terminals Inside Be Bent Over To One Side And Not Make Good Contact.
Unhook both negatives on the batteries. On one battery, touch the negative cable to the positive terminal. This will clear all the codes on the truck. If that makes no changes, see if there are any other codes.
Check your fuel filter and make sure its not clogged up.
How old is your oil? Make sure it is full.
Thanks for the info, guys. My truck started "dieing and restarting" or "hiccupping" tonight on the way home from work, (it was snowing).
The link and photos were fantastic. I think I can find it without too much trouble. Just released from physical therapy last week, so this sounds like a good first "mod" to try without putting too much strain on my back.
