e4od help ?
Old Nov 29, 2006 | 10:25 PM
delostruck's Avatar
delostruck
Question e4od help ?
Does any one have or know where I can get an exploded view of a 1995 e4od tranny also I need to know where the check ***** go in the valve body and the torque specs for the pump bolts I am trying to make one good tranny out of two bad trannys also how do you check the solenoid pack to see if it is good
Old Nov 30, 2006 | 06:47 AM
LEVEL10's Avatar
LEVEL10
Hello,
Call or send us your fax number and we can fax you the information you are looking for.
Mike
LEVEL TEN TECH
973-827-1000
