Trouble code and electrical problem.
Old Nov 29, 2006 | 08:17 PM
fordmustangfan67's Avatar
fordmustangfan67
Yesterday I got my first trouble code on my 2005 F250 6.0L. It was PO200. I see that this code is for the injectors. Any possible explanation for this. I haven't really noticed that the truck has been running any different. Only thing that I have done is changed fuel filters, but that was about 2 or 3 days before.
Also another problem that I have been having is an electrical problem. One night a while back I was driving home at night (with the lights on dim) and when I turned on my right blinker the high beam lights started to blink along with the blinker. Thinking that this was pretty odd, I then turned off the blinker and turned on the high beams. After doing this, the right blinker would also come on and stay on as long as I kept the high beams on. If I left the low beam on and the blinker off everything seemed fine. After shutting the truck off that night and coming back out in the morning the electrical problem was still present but went away after driving to town (about 12 miles away). Since then that particular scenario has not occured again but every once in a while, the battery light flashes. When I say flashes, I don't mean that it blinks, but it almost looks like it is insynch with the throttle position because as I increase the throttle, the light gets brighter. Likewise, as I decrease the throttle the light gets dimmer until I am not pressing the pedal very much at all. This problem also goes away as I drive usually a few miles. Anybody have a similar problem or any suggestions?
Thanks guys and sorry for the longer post.
Old Nov 30, 2006 | 09:50 PM
fordmustangfan67
Any help would be greatly appreciated. Thanks.
Old Dec 1, 2006 | 05:35 AM
BowTieHatr's Avatar
BowTieHatr
no code p0200 in my books. you sure about this code?
