Yeah, it's Chrysler's trademarked name for that feature. The one I drove was hit the lever left and right to shift, rather than up down, but same idea.
What is "auto-stick"? Is that where it's an automatic but you can push the shifter up and down in D to select gears?
Also know as a Powershift in some circles. It's been around since the early 1960's Basicly it's a manual transmission that you don't have to use the clutch to shift.
Auto-stick is not a manual transmission that you can shift without the clutch, it's an automatic you can shift manually. There is a difference between the two.
*The link doesn't work. When the error page loads, just delete the square bracket from the end of the URL and it works.
Ok that's what I thought it was. Over the summer I had a rented Jeep Cherokee that had that...worked ok as far as I could tell, had the left-right + or - a gear shifting thing.
hmm daily driver, tough question. How about a Powerstroke fully loaded with nitrous, propane, chip, exhaust, tranny upgrade, and a wvo system. Itd be fast and cheap on the gas with the wvo
1979 ford f-350 high boy with an aftermarket kit so i can put a 7.3 powerstroke in it, also with the banks kit in it. gooseneck hitch so i can pull the tractor around.
A small gas thrifty moped or similar. . .I'd be all about saving money for my weekend toys Shoot, if I could manage to live in an area where everything was in walking/biking distance I'd go that route
