1951 Master cylinder
Old Nov 29, 2006 | 04:53 PM
panningbros's Avatar
panningbros
I have a 1951 F2 that I want to update the master cylinder. The crossmember that used to hold the cylinder & rear trans support is gone. I would like to leave the master cylinder where it is. Has anybody used a kit of some sort that would bolt onto the frame about where the cylinder used to be? I think I want to use a manual cylinder or is power booster my only option? Thanks, Dave
Old Nov 29, 2006 | 07:15 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Where is the MC supported now? Firewall?
Old Nov 30, 2006 | 04:08 PM
panningbros
It doesn't have any master cylinder right now. The guy I bought it from was going to put a modern V-8 and auto trans and removed the original crossmember and put a new universal crossmember on in farther back on the frame. I need to either mount a master on the frame about where the old one used to mount or try and hang one from the firewall. I am not goint to tow or haul anything so I'm thinking manual brakes would be Ok or do I need power booster type. Some of you guys must have trucks running late model motor/trans combs. What have you got on yours? thanks,Dave
