fuel drain o ring ?
Old Nov 29, 2006 | 04:37 PM
luvemhot's Avatar
luvemhot
fuel drain o ring ?
I have had a small leak from the fule drain value I have the o-ring comming but today the small leak turned into major leak most of the was fule comming out of the drain hose. But i saw what looked to be fule comming out from where the yelow handle meets the top of the black value. Would bad o-ring do this or do i have a bad value?
thanks
Keith
Old Nov 29, 2006 | 05:07 PM
SpringerPop's Avatar
SpringerPop
You might have loose valve retaining screws. Got a #20 Torx driver?
Pop
Old Nov 29, 2006 | 05:31 PM
luvemhot's Avatar
luvemhot
both orings had flat spot's on them I will make sure the new ones are tight enough theyshould be here tomarrow
yep on the # 20 just not in 1/4 drive Will make sure i have a 1/4 inch drive when i put it back together
thanks
Keith
