I am experiencing a fuel leak on my 2002 F150 fx4 screw. Underside of the truck, about midway of the cabin, fuel is leaking fast while engine is running. Almost fast enough to call it a stream. It seems to be following a plastic channel, similar to the channel the oil flows when you are removing the oil filter for a change.
Closely check the fuel lines where they run under the cab. I've seen them rub through on the bottom of the cab.
They are a major pain in the neck to replace
That's what it was. It was pushed right up against the cab. Funny thing is, it actually blew out while in the NJ inspection station.
Yes sir, I did. Actually my buddy did. They gave me a 48 inspection sticker, so it had to be done quick. I'm not a mechanic, but really like fixing my truck myself but I'm to slow so I had a buddy replace the fuel line at his shop.
Jezzz jersey they failed me for cracked (CRACKED) tail light lens and a out plate light, I was pissed, the guy in front of me was blowin fumes rattling exhaust broken window on an 85 f150 with coat hangers supporting the ladder rack they passed him
