I have a 03 explorer that won't start.The other day it died and refired after 15 min. and been running fine since,but last night it died again and won't restart.The fuel pump is coming on and has fuel pres. to the intake.Was wondering about a cam position sensor.Any ideas will be great.
If so, try unplugging the Mass Air Flow.. if it starts then, remove the sensor and look for a broken element or debris stuck to it... most of the time you can just clean it off real well.
Other than that there's really nothing common on these that can cause a no-start... try borrowing a scanner and see if there are any codes stored.. if so report them here maybe we can help you out more.
Ok i hooked up scanner (telstar) and found nothing. No codes and everything passed on test. And now it started up and runs fine. I was wondering about the pick-up bye the harmonic balancer.
It was siting in the driveway.Started it up and died and wouldnt start back tues.or wed. tried it sat. and it started and been running fine since. So i guess i will wait till it dies again.
