Rear Axle???
Old Mar 27, 2002 | 09:41 PM
darkhorse54's Avatar
darkhorse54
Rear Axle???
Old Mar 30, 2002 | 05:45 PM
f4fran's Avatar
f4fran
Rear Axle???
My 52 F-4 has a Split Housing Sprial Bevel type rear axle with 5.14:1 ratio.
Question 1. What is the diameter of the ring gear? (9 inch, 10 inch, etc.)
Question 2. Has anybody converted one of these rear ends to a limited slip type, using, of course, the original axle housing, gears, etc??
Thanks,
Fran
Old Mar 30, 2002 | 06:27 PM
286merc's Avatar
286merc
Rear Axle???
Good Luck! Thats the same case and ratio in my 54 F350. There were some ratios made in the 4's according to my 48-55 Parts manual but forget about adapting anything modern inside.
Best bet is to measure what you have and hit a truck boneyard. The Dana 60 series was very popular in F250/350 pickups and vans and had stick shift and automatic ratios available along with posi. Mid 1960's thru late 80's at least.
There is a standard and HD dana 60, the difference is in the axle tube diameter.
Adapting is usually just a matter of moving spring perches and using the new wheel pattern.
