pressure for hpop
Old Nov 28, 2006 | 08:29 PM
oldblue31's Avatar
oldblue31
pressure for hpop
What is normal presure for the hpop?Mine is 47 psi
Old Nov 28, 2006 | 08:43 PM
ltfox's Avatar
ltfox
Are ya talking fuel pump psi??? HPOP should be up around 500psi at idle. 47 psi sounds about right for fuel pressure.
Old Nov 28, 2006 | 08:59 PM
oldblue31's Avatar
oldblue31
Sorry! Did'nt think about what i was thinking before I said what I thought.I meant fuel pressure.Is the stock hpop sufficient for 160cc injectors?
Old Nov 28, 2006 | 09:03 PM
96powerstroke's Avatar
96powerstroke
i have not done injectors myself, but from what i have read from the great folks here, stages 1s are about as big as you can go with the stock hpop, even then though you might get a cel. dont quote me on that but i believe thats what i read if i recall correctly
Old Nov 28, 2006 | 09:16 PM
ltfox's Avatar
ltfox
If your pump isn't already weak you should be fine. And like stated above...on the hotter programs with a chip...its very possible to set a CEL.
