xm radio antenna
xm radio antenna
i know this doesnt have much to do with superduties but im running my antenna wire and i ran it through that little hook thing under the power point, behind the fuse box and up the door through the weather seal and underneath the windshield trim .. seal thing...anyways when the wire comes out it causes the weater trim seal around the windshied to come up a little bit....will this cause a water problem or is the the windshield seal below that trim?
I just installed mine on the top of the dashboard, in the center, towards the windshield. My buddy told me he did it on his F150 and it worked fine. I liked the idea of not having that stupid antenna scratching the paint on my new truck. I didn't care on my old F150. So far it is working just fine there. Give it a try, it beats fishing that wire though your weather stripping too.
i also ran mine up through the windshield seal, and i live in a VERY rainy place.... but i didnt seem to get any leaks. however, i did get aweful reception. i installed one exactly the same on my wifes xterra, and hers works great. do you think i am getting some interference from something, or that i just maybe have a bad antenna? what are your thoughts? thanks in advance !!
Personally, I used a Metra adhesive-mount antenna (helps to be a dealer...) and mounted it just ahead of the third brake light. The wire runs through a notch in the brake light (sealed with a small bead of black RTV) and down the C-pillar, to the XM unit mounted behind the rear seats (Pioneer 7800 head with integrated XM).
I did something similar with my '01 Expedition and it worked great.
I ran mine under the plastic kick plates that cover the gap between the carpet and the body as you get in the truck. Heck, I run all kinds of stuff under them. I ran it up the rear driver side pillar plastic and out the edge of the door frame.
Question- does anyone have interference issues? Mine get's a lot of static that goes away when I touch my hand to the top of the unit, almost like I give it an electro-static ground or something. If I put a bag of Red Man (silver foil lined) on top of it, it solves the problem, but looks stupid. Any suggestions?
Mongo - I suspect you're using a Roady or other type of FM-modulated unit? If so, touching your hand/applying the Red Man bag is changing the characteristics of the "antenna" inside. Your best bet would be to go to something that's direct-wire - get one of the PIE adapters for an aux input, etc. Then, there won't be a reason for the static.
Originally Posted by 6L PWR
I've had mine done this way for the past 9 months with no issue so far. The only time I'd be worried is if I have to have the windsheild replaced. The repair places never get it sealed as well as the factory. If that day comes, I may do it like BearHunter did. Not going to change it now since it took me a month to get off my a$$ and do it the first time. lol
yeah now that i hear of people doing it this way with no problem im going to keep it like this but bear hunters is really clean looking and a very smart idea...but like you it took me forever to run it this way...***** i had the antenna just sitting on my dash sliding all over the place with wires ran everywhere for about 2 months only because i was to busy with work and when i had time i was to tired...so im going to kepp it this way...by the wway i havent come up with a question that hasnt been answered yet on this website...you guys do an awesom job of not only answering the questions but explaining in detail...thanks for everything
