Sponsored by: Kumho
help! Can't get my wheels off!
Old Dec 2, 2006 | 03:03 PM
jjoel's Avatar
jjoel
i would usually like kick my tire the opposite direction. i had the same issue with my 325i but then again if a truck tire is frozen on, that would be really difficult to get off.
Old Dec 2, 2006 | 07:47 PM
jake00's Avatar
jake00
mine were stuck on, but a 4x4 and a 10lb sledge got it done
Old Dec 3, 2006 | 10:50 AM
daddio360's Avatar
daddio360
ah, not enough lumber, eh? maybe a 6x6 would be better yet!
I just had an idea...tell a customs agent there's a bag of drugs behind the wheels.
Old Dec 3, 2006 | 01:50 PM
rebocardo's Avatar
rebocardo
Well, I posted a long explaination in the topic that disappeared. If you want more tips search for my name with "+explorer +tire".
One post said to hit the tire with a hammer, I said it was a poor idea.
Old Dec 3, 2006 | 03:59 PM
dechiknhaulr's Avatar
dechiknhaulr
Take the lug nuts off and spray the stud holes and center opening with 'PB Blaster'. Put the lugnuts back on and drive it for a day or two. When you try to remove the wheels after soaking with Blaster, they should come off without much trouble.
Once you get the wheel off, apply a moderate amount of 'Anti-Seize' to the center opening and the back of the rim surrounding the stud holes.
Old Dec 3, 2006 | 04:05 PM
thefarelaneman's Avatar
thefarelaneman
That PB BLASTER is good stuff
Old Dec 3, 2006 | 04:17 PM
daddio360's Avatar
daddio360
Thanks to all...the last suggestions came a little too late as I got them all off today...I'll check out that anti=sieze stuff. The one (front) wheel came loose with Beaner's method, one back one with the sledge & wood, but the third I actually had to use a bottle jack against the frame...whew! I guess this is one case for rotating your tires regularly...these had not been off in 7 years.
