No start
Old Nov 28, 2006 | 04:18 PM
John Squire's Avatar
John Squire
No start
I have a 83 F150 flareside with 302 c.i. , AOD transmission. The following electrical items are brand new battery, starter, solenoid, voltage regulator, and alternator. I have a situation of intermittent no start. When you turn the key it is if the battery is totally dead. Engine does not turn over when this occurs. Any ideas.
Old Nov 28, 2006 | 04:37 PM
cummins's Avatar
cummins
How do you get it started when this happens.
Old Nov 28, 2006 | 04:54 PM
John Squire
A variety of things. Wait for ahile retry. Wrigle ignition key. Jump start. I don't know which is actually working and why
Old Nov 28, 2006 | 05:52 PM
cummins's Avatar
cummins
If the batery isnt dead is there power going the solenoid.The solenoid could be defeective if iit has power to the S terminal when in start position.If no power to S terminal the ignition switch may need adjusted or be defective.
Old Dec 2, 2006 | 10:49 PM
Montana Dust's Avatar
Montana Dust
Do you have power to the rest of the vehicle in the key-on/engine off position?
Could be the nuetral safety switch has an intermitant bad connection.
The ignition switch under the steering collum would be my first check, after years of wear the rod from the tumbler may not be pushing it all the way to "start". Do you normaly have to turn the key hard to get it to start?
Old Dec 2, 2006 | 11:16 PM
John Squire
Thanks for the info. I wil try that Monday. That really seems logical
Old Dec 3, 2006 | 09:50 AM
locknkey's Avatar
locknkey
Electrical ignition switch under column.....NOT Key Ignition switch. Drop column, locate elec. Ign. SW. remove the two screws, replace rod in same hole has it was when you removed it from. Start an enjoy.
