jag parts
Old Nov 27, 2006 | 11:53 PM
lt56's Avatar
lt56
jag parts
is the jag rear end a viable swap? A cousin of mine has a couple of wrecked ones and voluntered the parts.Any other parts worth grabbing?
Old Nov 28, 2006 | 04:44 AM
halfdone's Avatar
halfdone
Front ends and Rear Ends, if you don't use them someone else here will.
Instruments and seats normally fetch a few dollars at swaps. Also fuel caps, taillights etc
Check out what bit's are being sold on ebay, and grab those bits off the wrecks ...... ebay is a pretty good guide to what bits are worth anything.
Old Nov 29, 2006 | 12:06 AM
lt56's Avatar
lt56
Any info on how hard suspension is to hang on frame?
Old Nov 29, 2006 | 06:08 AM
texan2004's Avatar
texan2004
The front end is pretty easy, particularly on the 48-52's. The rear end is a bit more work since you will want to build a cage for it but even that is not really all that bad. You also have to box quite a bit more of the frame.
Old Nov 29, 2006 | 09:00 PM
axman's Avatar
axman
read this. tons of info.
https://www.ford-trucks.com/forums/2...hlight=jag+ifs
Old Nov 29, 2006 | 10:11 PM
RUSTY50F1's Avatar
RUSTY50F1
Where are they located I'm in OKLA could sure use an IFS.RUSTY
Old Nov 30, 2006 | 07:53 AM
AXracer's Avatar
AXracer
Just be sure they are the right years and model, you DON'T want an XKE (except to resell the rear to hot rodders or Jag restorers) for example. The links to uncage the rear, swap other gear ratios etc are readily available from aftermarket sources. The rear is useable as is with just simple mounts needing to be fabricated but most remove the rather bulky cage for asthetic reasons. There's a lots of bling points in being able to see all the moving parts, and without the OEM cage it's a pretty trim unit.
Old Dec 2, 2006 | 10:57 PM
lt56's Avatar
lt56
nice thread
Thanks for the jag link ,took forever to read through ,but worth it.On another note on searching archives.Cant seem to search,only available to members?
Old Dec 2, 2006 | 11:23 PM
AXracer's Avatar
AXracer
Search is turned off for everyone temporarily.
Old Dec 4, 2006 | 05:47 PM
axman's Avatar
axman
yea that's the tread that started me thinking i got a 86 xj6 waiting in the wings
do a search on the h.a.m.b.
http://www.jalopyjournal.com/forum/index.php?
