Wiring Trailer Harness
Old Nov 27, 2006 | 09:54 PM
Claybe's Avatar
Claybe
Hey All!
I went to plug in my Truck Camper and there is no power to the right (green?) side. I check the plug with a test light and nothing. I then checked the harness where it breaks off to the plug at the back and nothing. Where should I go from here? The steering column has some issues as you have to wiggle the emergency flashers to get them to work. Then, the turn signals sometimes work on the column, but always work on the truck. The wiring diagram I have is not too helpful. So...
Is there a seperate wiring system from the steering column to the back of the truck or does it run off of the back of the truck (it looks like it is seperate)?
Where should I check to see if there is a short or bad connection?
I checked the fuses and they are all good. Please help!!!!
Thanks in advance!
Claybe
P.S. It's a 1992 F-250 4x4 Extended Cab 7.5L 460 with 100,000 miles.
