apparent intermittent vacuum pump failure
Old Nov 27, 2006 | 09:25 PM
fellro86's Avatar
fellro86
My dad's 84 F250 seems to have an intermittent failure. The pump is new, but it seems like it cuts out every so often. The light comes on, brakes go hard, then the light goes out, and good assist. Is there a check valve or such on the pump that would do this? I'm used to either it works or it doesn't, haven't seen one behave like that...
Old Nov 27, 2006 | 09:33 PM
PLC7.3's Avatar
PLC7.3
Check all the vacuum lines and the coffee can underneath for leaks and holes. If you want the vacuum test email me....... just click on my name.
Old Nov 27, 2006 | 09:43 PM
fellro86's Avatar
fellro86
No coffee can, no factory air or cruise, basic stripped down version. Go ahead and fire off an email if you can get it through the system,. If not, I'll send it to you so you can go direct.
Old Nov 28, 2006 | 12:49 AM
CheaperJeeper's Avatar
CheaperJeeper
Dunno' about the vacuum pump, but I'm pretty certain there is a check valve in the brake booster. Kinda sounds like maybe the booster is leaking - either the check valve, the vacuum line, or the diaphragm.
Old Nov 28, 2006 | 09:25 PM
bc6.9's Avatar
bc6.9
The check valve cheaper was referring to is a common problem...mind you I have gone thru 3 vacum pumps in 10 years.
Old Nov 28, 2006 | 11:20 PM
fellro86's Avatar
fellro86
Isn't the little plastic elbow into the booster the check valve?
Old Nov 29, 2006 | 03:44 PM
bc6.9's Avatar
bc6.9
That's it.
