Window Spots
Old Nov 27, 2006 | 06:45 PM
lawnspecialties's Avatar
lawnspecialties
Window Spots
Does anyone know of an effective way to get rid of water spots on my F-250's windows? The windshield, door windows, and back glass all have those pesky water spots that won't budge with glass cleaner. I'd imagine there's some good "home remedy" for getting my glass close to new condition. Thanks
Old Nov 27, 2006 | 10:09 PM
lucas restoration's Avatar
lucas restoration
buff them with a cutting compound or cleaner type wax
Old Nov 28, 2006 | 09:46 AM
beartracks's Avatar
beartracks
If i's really bad use Bon Ami and 0000 steel wool or a rough rag and lots of elbow grease.
Old Nov 28, 2006 | 03:22 PM
thefarelaneman's Avatar
thefarelaneman
An old "trick" used by used car dealers is to clean all of the glass using a razor blade. Then if you still see spots they are more than likely inside the glass and cant be removed.
Old Nov 29, 2006 | 10:01 AM
beartracks's Avatar
beartracks
The razor blade trick work for really bad stuff but wont get it all. Eastwood sells a glass polishing kit to use on your drill that work pretty well. Still takes time but much easier on the arms.
Old Dec 1, 2006 | 10:27 PM
Autoglass's Avatar
Autoglass
Try some vinegar, get a small spray bottle or soak a paper towel and put it on heavy to the glass and wipe it dry with a strong paper towel. Windex wont cut it? Try the vinegar, we use it on the windshields we get from overseas. It work well for us.
Old Dec 1, 2006 | 10:56 PM
snowbilt's Avatar
snowbilt
Just get yourself a claybar and some detailer spray. Any self respecting DIY auto detailer wouldn't go with out it. I had a water trail on my newly purchased 05 navigator backglass. Some elbow grease and viola gone! I have heard of the steel wool and bon ami thing, but if you look on the can it says not for use on glass.
Old Dec 2, 2006 | 03:28 AM
tdister's Avatar
tdister
If the above methods don't work, I will 2nd the Eastwood products. As a bonus, they are an FTE Sponsor . They have lots of other great stuff too.
http://eastwood.resultspage.com/search?p=Q&ts=custom&w=glass+polish&submit.x=0&sub mit.y=0&submit=Search
