Offroad & 4x4
coils or leafs
Old Nov 27, 2006 | 03:44 PM
Boz Turner's Avatar
Boz Turner
coils or leafs
i want to swap out my dana 44 to a dana 60 front axle my question is should i use leafs or coilsprings i already have skyjacker coils i'm thinking of useing kings or fox. the skyjacker kit is ok just looking for somthing abit more stout. any input would be nice
Old Nov 27, 2006 | 04:51 PM
SoArkSI's Avatar
SoArkSI
you can use your coils, you just have to take off the leaf mounts and fab on the coil spring c's jeffs bronco graveyard sells them. thats what i am going to do with my truck. you can do a leaf spring conv. or coilovers but someone else will hafta chime in on this one.
Old Nov 27, 2006 | 05:44 PM
chrono4's Avatar
chrono4
what are you going to use it for? coils will usually flex better for rocks/ trails. Im pretty sure only certain year 60's can be converted because of how the spring perches are cast on to some.
to go to coils, means cutting off old perches, welding on the C's, making trac bar/bracket.
going to leafs means front and rear spring mounts, different steering. I know I'm leaving out alot, but this is the jist of it. I went to leafs on my 88, and kinda regrett it because I couldnt move the axle as far foward as I really wanted it.
Old Nov 27, 2006 | 05:59 PM
fishmanndotcom's Avatar
fishmanndotcom
coils
-cutts-
Old Nov 27, 2006 | 07:11 PM
75F350's Avatar
75F350
When you spoke of Kings or Fox, were you refering to using a coilover, or just the shock? The real cool set-up would be to ditch the big coil, and use a coilover. Sway-away makes a dual rate coilover, thats one spring stacked on top of the other. Giving the driver a super plush ride. The two springs have different rates, the top one with less rate. Soaks up high speed whoops with no problem, and works well on the slow stuff too. Rancho just introduced a new line of coilovers, but are slightly limited on rate options. The advantage to the sway-away is the ability to really dial in the eibach springs. Because it is a coilover, even ride heigth can be adjusted. If you are gonna use a racing style shock such as the king, or fox, then you are not afraid to spend a little dough. As long as you are gonna spend it, consider a few more options.
Old Nov 27, 2006 | 08:44 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
coils....leaves bring on a new problem....axle wrap
Old Nov 29, 2006 | 09:09 PM
Boz Turner's Avatar
Boz Turner
Thumbs up kings
king coil overs on the front and deaver springs on the rear with some king smoothies on the rear. I also found the fab shop i'm going to use so it's just a matter of time till i get it in the shop probly early january
Gasgzlr
Jan 18, 2017 11:01 PM
800screws
Oct 14, 2015 07:03 AM
quincyj34
Sep 16, 2015 07:25 PM
1badcj8
Dec 14, 2014 12:55 AM
jad4
Jun 14, 2005 09:42 PM
