help idle
Old Nov 27, 2006 | 12:19 PM
dumdum9599's Avatar
dumdum9599
help idle
help my truck is idleing way to low i mean like 400rpm and i can't find the idle adjusement but need it fixed
Old Nov 27, 2006 | 08:22 PM
clunker86's Avatar
clunker86
what size of engine do you have. almost all the carbs i seen on a 351m/400 should be on the driver side of the carb. it should be one screw that will push the throutal cable awy from you. look where you gas pedal cable conects to the carb and you should find her
Old Nov 28, 2006 | 04:29 PM
dumdum9599's Avatar
dumdum9599
oh i know what you are talking about thanks for your help
