Broken Rod Bolt
Old Nov 26, 2006 | 11:24 PM
JET EDWARDS's Avatar
JET EDWARDS
rod help
i have a 302 all rod bearings were copper and replaced em but i broke one of the studs do u know a way i can fix this one rod myself without pulling the engine. thanks
Last edited by Torque1st; Nov 27, 2006 at 12:14 AM. Reason: moved from 3+ yr old thread.
Old Nov 27, 2006 | 12:15 AM
Torque1st's Avatar
Torque1st
Posting Legend
Split and moved to proper forum.
Old Nov 27, 2006 | 01:01 AM
TigerDan's Avatar
TigerDan
Technically, when the rod bolts are replaced the rods should be resized. This of course requires complete disassembly of the engine. This might be a little iffy but should work in a pinch. I would try to carefully remove the broken bolt (without damaging the rod journal on the crank) and insert a new bolt, pulling it into place with the nut.
Old Nov 27, 2006 | 04:37 AM
baddad457's Avatar
baddad457
I've changed out a whole set with an assembled 5.0. Stock bolts to ARP's. Works fine without resizing the rod. I don't think I'd try it with stock bolts, you need to torque the bolt a couple times to get it seated all the way into the rod. Stock bolts are not very strong, as you've already found out. They've always been the weak link in a 302.
Old Nov 27, 2006 | 06:59 AM
EPNCSU2006's Avatar
EPNCSU2006
Were you able to measure the roundness of the rod afterwards?
Old Nov 28, 2006 | 06:09 AM
baddad457's Avatar
baddad457
No. But I ran this engine daily, with "freeway blasts" up to 6500 rpms for well over a year. Then swapped heads, intakes and lifters and ran it another 4 months with blasts to 7500 rpms almost daily before it cracked a cylinder wall. The rotating assembly held up fine. It would have gone longer had that one cylinder wall not cracked and leaked coolant into the oil. This wasn't a high dollar short block either, the short block was built by City Motor Supply in Dallas Tx. Cost me $350 (exchange) Bored 40 over and had Silvolite Hypereutectic pistons.
ND_Stroker_6.0
Sep 6, 2016 02:03 AM
Lg2008
Mar 5, 2016 02:59 PM
mtnxtreme800
Aug 14, 2012 07:00 PM
nrskel78
Nov 16, 2011 03:56 PM
ahron11
Jul 4, 2009 03:21 AM
