06 Explorer Problem
Old Nov 26, 2006 | 09:54 PM
davidn's Avatar
davidn
06 Explorer Problem
anyone else have this problem? Just before I come to a complete stop, the engine revs to 1200-1600 rpms and then settles back down. It happens at almost evey stop. The dealer told me they have about 25 other similar complaints. I have no confidence they will fix it.
Old Nov 27, 2006 | 05:02 AM
marragtop's Avatar
marragtop
Pull the codes and see what they are.
Old Nov 28, 2006 | 10:37 PM
davidn's Avatar
davidn
how do i do that?
Old Nov 28, 2006 | 11:14 PM
kevin74656's Avatar
kevin74656
If your vehicle is still under warranty (which I assume it is), you should have your Ford dealer pull any codes that may exist. Otherwise, you can go to AutoZone or Schuck's and they'll read the codes for you for free.
If you have no confidence in your dealer's competence (or willingness) to solve the problem, then go to another dealer. If there are "25 other similar complaints" as he claimed, then Ford should be aware of the problem, and a technical service bulletin probably exists.
Good luck!
Old Nov 29, 2006 | 06:47 PM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
It's very possible that this is a common problem, and that Ford is still working on a fix (likely a computer update or something of the like)...
Make sure that you get documentation that Ford WAS able to duplicate the problem, but not able to repair it at this time.. that way if a repair comes out after your warranty is expired, they will have no choice but to repair it for free.
If you don't get this in writing, if you run out of warranty you probably won't get it taken care of.
Good luck.
Old Nov 29, 2006 | 09:51 PM
davidn's Avatar
davidn
Thanks guys. The truck is only 5 months old. I test drove another with 6 miles on it and it did the same thing. I do plan on getting it in writing.
Old Jan 22, 2007 | 09:05 PM
torexplorer's Avatar
torexplorer
Try looking into this...
Sorry to revive an old post...I'm new to this site. I recently bought an '06 Explorer 4X4 V6. This could be the TSB that anyone with this problem needs to investigate:
POWER TRAIN:AUTOMATIC TRANSMISSION
  • TSB #05236 -- HARSH OR DELAYED 1-2, 2-1 AND/OR 3-2 SHIFT. *TT (NHTSA ID #10019029, JANUARY 01 2006).
Good Luck.
cdmm151
2009 - 2014 F150
44
Sep 24, 2017 01:14 AM
FrankRG
Modular V8 (4.6L, 5.4L)
Dec 21, 2015 08:33 AM
mrwrench
Jun 2, 2014 09:15 PM
vze2sgxa
Jan 19, 2006 06:24 PM
