front end problems
Old Nov 26, 2006 | 09:01 PM
darrmann's Avatar
darrmann
front end problems
when i have it in 4 wheel every once in awhile theres a bad clunck,baang im not sure what to call it but it doesnt sound good any ideas
Old Nov 27, 2006 | 07:14 AM
Duncan10's Avatar
Duncan10
Could be any number of things. Are you on hard pavement or loose dirt? Check your u-joints on your drive line. Could be jumping chain in T-case. A little more info would sure help. Is it coming from front end or ?
Old Nov 27, 2006 | 07:59 AM
darrmann's Avatar
darrmann
more info its when im on pavement driving along in 4 wheel,its in the drivers front .it sounds like its coming from the wheel but can a u-joint bang so bad
Old Nov 29, 2006 | 06:58 AM
Duncan10's Avatar
Duncan10
Well as far as I know you shouldn't run your 4x4 on pavement with it locked in. The 4x4 need to slip especially when turning corners. The banging could be one of your front hubs letting go then locking back in or it could be in the front diff.
