VSS out maby
second that noise goes away when i apply the breaks
third my speedo works when im moving with insane buzzer but when im breaking with no busser it reads 27 ish mph and side note it make my odmeter go up aswell
though of takin out vss sensor and blowing it off wiht air or something as i wrote this. but no light on dash dunno if a tester will catch it ? and of corse anyone know for a fact a way to fix ~~
Ford can read and comunicate with those systems, for $500-1500 you can too. Other wise you can try to pull a code from the cluster. Google cluster diagnostics and you should find the instructions, layout and what some of the codes mean.
