engine washing
Old Nov 26, 2006 | 06:54 PM
2jhanna's Avatar
2jhanna
engine washing
for years i have always washed/cleaned my gas engines either at a car wash or at home by spraying a bottle of 409 or simple green then rinseing with water.
any reason the same can't be done with this diesel ?
any thing to look out for ?
Old Nov 26, 2006 | 07:23 PM
bc6.9's Avatar
bc6.9
You're not suppose to wash IP when its has been running at regular temps...you're supposed to wait till it cools down....thats the only warning I have ever read.
Old Nov 26, 2006 | 10:26 PM
Dave Sponaugle's Avatar
Dave Sponaugle
When I have time, there is a car wash just down the street from me.
First start of the day I drive down there and wash the engine bay and engine.
But the engine temp is lower than the wash water at the car wash when I get there.
The only thing you have to watch is spraying cold water on the IP when it is hot.
When the engine is cold or barely warm, spray it all off.
Old Nov 26, 2006 | 10:50 PM
2jhanna's Avatar
2jhanna
thanks,
i always hate working on a dirty engine, it usually makes what ever your doing even more of a hassle.
i usually wash off my other vehicles' engines and under carriages 3-4 times a year , usually right after i change the oil.
Old Nov 27, 2006 | 12:07 PM
az7.3's Avatar
az7.3
I have washed down my engine and the "water in fuel" lite comes on and after a few minutes it goes off. Is this normal or am I seeing something that should concern me?
Old Nov 27, 2006 | 08:40 PM
bc6.9's Avatar
bc6.9
I had the same problems with my 86...temp light would stay on up to two days??
Old Nov 27, 2006 | 11:49 PM
tbone91's Avatar
tbone91
As susceptible as these trucks can be to wiring problems, I'd think twice before putting
water under the hood. I had an 86 gasser that I gave away because I got tired of problems
with bad connections everywhere under the hood.
That said, I'd rather work on a clean engine any day...
Old Nov 28, 2006 | 08:46 PM
Dave Sponaugle
tbone91,
Welcome to FTE and the IDI diesel forum.
