Need help decoding rear axle tag
Old Nov 26, 2006 | 05:00 PM
Sweet Christine's Avatar
Sweet Christine
Smile Need help decoding rear axle tag
Hello everyone!
I need help decoding the little metal tag attached to the rear axle. I have a 1992 F250 4 x 4 with a 351/auto. The tag has two rows of numbers/letters:
" 2 V1240 "
" 3.55 10 2 1 H02"
I think the 3.55 is the rear axle ratio. I want to know what type of rear end it is and what type of fluid I should put in it for maintenanace purposes?
Thanks everyone!
ps. is there an easy way to i.d. the front axle too?
Old Nov 26, 2006 | 05:07 PM
77bigblock's Avatar
77bigblock
The best way to find out what you have is to look on the drivers door post. Look on the sticker their under axle and see what the codes say. You do have 3.55 gears. If you have a letter with a number, then you have limited slip and will need some additive. If you are changing the differential oil, then I would put synthetic in it. If you have a F250 HD you have a 10.25 full floating sterling rear with a D50 front. If you have a F250 LD then you have a D44 front and semi-float something else in the back.
Old Nov 26, 2006 | 05:17 PM
Sweet Christine
Smile Decoding rear axle
Thanks.
I looked at the door tag and it says "39" under axle . How do you tell if the truck is an HD v.s an LD ?
Old Nov 26, 2006 | 05:41 PM
EPNCSU2006's Avatar
EPNCSU2006
What is the GVWR on the door sticker?
Old Nov 26, 2006 | 05:47 PM
Sweet Christine
Ok , this sticker says GVWR 8600 lbs
Old Nov 26, 2006 | 06:04 PM
Sweet Christine
Is it a HD?
Old Nov 26, 2006 | 06:14 PM
77bigblock's Avatar
77bigblock
http://www.drivetrain.com/Fordtrkratio_posidata.html
According to this site, it is a full floater. That means you have an HD. I also believe that Ford considered 8500 lbs and over heavy duty.
Old Nov 26, 2006 | 06:16 PM
EPNCSU2006's Avatar
EPNCSU2006
Yep I think the LD 250 was in the 7500 GVWR area
Old Nov 26, 2006 | 06:33 PM
Sweet Christine
This is great information. Thanks for the website about powertrains. This will be useful for other stuff too.
Old Nov 26, 2006 | 06:48 PM
77bigblock's Avatar
77bigblock
I got that website from somebody on here when I had the same questions. I am happy to pass it along.
