Cab mount removal tips?
Old Nov 26, 2006 | 12:51 PM
Stevan's Avatar
Stevan
I tried to search, but not allowed.
I just picked up a 94 cab at the junkyard to replace my rusted 83. I tried to remove the rubber mounts from the 94 with no success. From the drawings in the chilton manual, they separate top and bottom, any trick for this ?
Should I just buy new ones.
Thanks,
Steve.
Old Nov 29, 2006 | 10:53 AM
Stevan's Avatar
Stevan
So, no advise? I may try again by getting a longer bolt, threading it in and hammering down on them. It would probably work better if the rubber diddn't cushion the impact.
Old Nov 30, 2006 | 03:26 PM
CLA4JC's Avatar
CLA4JC
I have never removed body mounts but I used a propane tourch to burn them out. It would probably work for body mounts too.
Old Nov 30, 2006 | 10:55 PM
Stevan's Avatar
Stevan
Went back to the yard today and used one of the original bolts from the rear cab mounts. I was thinking it wouldn't be long enough, but there is some spacing in the cab, so it was more than long enough, threaded it in, and smacked it a few times with a BFH (good sized hammer), and violla..., or whala...?, each one popped out easily. I felt stupid for not thinking of it when I removed the cab.
CLA4JC, I was trying to save them to use when I install the cab on my 83, but thank you for your input.
