crossdrilleed or not?
Old Apr 14, 2002 | 01:44 PM
58ford's Avatar
58ford
Howdy All!
I am currently putting together a 1958 ford f100 and i am having some trouble witht he cam. I have bought two sets of cam bearings and the cam is TIGHT when I put it in. I've had the cam redone and it is within specs. I have looked through some old books and have found cam bearings for a crossdrilled cam. Can anyone tell me how do I tell if it is crossdrilled or not? thanks.
Old Apr 14, 2002 | 10:47 PM
cobraguy's Avatar
cobraguy
What engine are we talking about?
Old Apr 15, 2002 | 12:27 AM
58ford's Avatar
58ford
sorry bout that it's a 223
Old Apr 16, 2002 | 08:16 PM
rogerf100's Avatar
rogerf100
RogerF100
'55 F100
A cross drilled cam means it has holes drilled in the journal at 90 degree angles for oiling to the rocker arm shaft. A better choice from later years is a grooved journal cam. Instead of holes drilled, it has a groove all the way around the journal. This was a change made by Ford around 1958. You must use the proper cam bearings for the type of cam you have for proper oiling of the rocker shaft. If the cam is tight you may need to ream the bearings.
Old Apr 28, 2002 | 11:34 AM
jniolon's Avatar
jniolon
old and in the way
Old Apr 29, 2002 | 12:04 AM
58ford's Avatar
58ford
Post crossdrilleed or not?
Thnaks for the info. I have a machine shop getting on reaming the bearings for me as we speak. Hopefully i'll have picts of it--minus paint soon. Thnaks again......
