'56 for towing RV's
Old May 1, 2002 | 12:49 AM
SABBATH's Avatar
SABBATH
'56 for towing RV's
just bought a 1969 19.5 ft Terry tandem axle self contained camp trailer and want to tow this trailer with the o'l f100. my truk came wit a 6 banger originally so she's got 7 leafs in back, 8 in front. what should i upgrade to for towing? and what about shocks? i belive i'll have to weld on a receiver hitch as well. i am planning on doing the disc brake conversion for the front so i can slow her down cause we gots some steep mountain passes here in colorado. by the way, rear axle is a ford 9 inch.
thanx in advance for any info gents
SABBATH
Old May 1, 2002 | 01:25 AM
cabby daddy's Avatar
cabby daddy
'56 for towing RV's
Old May 1, 2002 | 06:52 AM
Caddy 53's Avatar
Caddy 53
'56 for towing RV's
SABBATH:
My experience is to install class 3 or 4 load leveling hitch w sway bar or bar's and level lift arms. If using auto tran then 15000 # tran oil cooler in series w/ radiator. Stiffen rear susp. for stability (shocks,spring, tires). Install a electric brake controller .Feed electric trailer plug w good wiring technics and gauge size. I may use self reset circuit breaker on elec brk circuit. Make sure the radiator in good shape. You may want to chg gear ratio. 3.73 depending on hills or mountains. To much carb on hi altitude don't work well.
IF done right you will get a long fine. Don't short cut safety.
Caddy 53 chuck
Old May 1, 2002 | 11:22 AM
SABBATH's Avatar
SABBATH
'56 for towing RV's
for stiffening rear end for stability do you have any concrete recommendations? air shocks? f250 springs? tires? thanks for the input
SABBATH
Old May 1, 2002 | 07:26 PM
Caddy 53's Avatar
Caddy 53
'56 for towing RV's
Sabbath: Remember that this truck is about 50 yr old .Don't overload it. A longer wheel base would be better.
Minimum tire- 30x9.50 15" LT 6 ply
Shock- Monroe gas magnum I don't care for air shock
Spring- 250 ? At least beef second leef below main leef buy adding another. I would prefer to have at least 1-2" of positive arch when loaded.
I realy think you should give this a lot of thought befor doing it.
How are the following?
Engine
Tran
Clutch
Steering Real important
Brakes
General condition of truck
Tires
Have you ask Horsepuller ,in the tow forum, for an opinion?
This is good topic for that forum.
These have only been my opinon's and I sure there are those who agree and disagree w/me.
GOOD LUCK BUT BE SAFE!!!
caddy 53 chuck
SABBATH
Oct 3, 2009 09:18 PM
effie_man
Jan 29, 2007 09:31 AM
jseim44
18
May 31, 2006 07:43 AM
SABBATH
May 2, 2002 09:26 PM
SABBATH
Apr 26, 2002 10:22 PM
