1978 - 1996 Big Bronco
Is there a real answer to a p1351 code?
Old Nov 25, 2006 | 05:07 PM
MattA's Avatar
MattA
i have a 96 eb bronco with a 351. the MIL comes on after the second time being started after clearing the codes.
The code is p1351 (Ignition Diagnostic monitor circuit input malfunction)
i have searched these forums and many others and found that a lot of other people have been getting this code as well, but there isn't an answer to fixing it.
i have replace the pcm, icm, coil, distributer,cap ,rotor and plugs and checked all the wiring to the best of my ability. i have even tried running the groung wire from the alternator directly to the negative battery cable(don't know where i found that idea).
i was just hoping that someone out might know the secret to getting rid of this code.
thanks
Old Nov 25, 2006 | 10:44 PM
Bob 86's Avatar
Bob 86
Did you get a Ford icm? I had the same problem with my 96 when the icm went bad. Turns out the Ford parts catalog, and napa application is wrong, if they gave you a gray icm. The correct one should be black in color. After talking with a Ford enginer they figured this out, and my p1351 is gone. The black module is listed for a 4.9L engine, which is incorrect.
Old Nov 26, 2006 | 06:05 PM
MattA's Avatar
MattA
i have tried three different icm's (grey one from autozone, white one from carquest and a black one from ford) all of them seemed to work the same and still threw the code.
thanks for the reply!
i'm going to take it to work tomorrow and have one of the older and wiser techs look at it.
obs_psd
Mar 10, 2015 06:35 PM
85lebaront2
Electrical Systems/Wiring
Mar 29, 2014 03:00 PM
Harrier
Jul 29, 2013 09:16 AM
SmokeBlower
35
Oct 15, 2009 07:17 PM
SmokeBlower
Dec 14, 2008 04:56 PM
