dana 60
Old Nov 25, 2006 | 04:40 PM
soup2nutz's Avatar
soup2nutz
dana 60
I aqquired a dana 60 front axle to swap into my 89 f-250 hd 4x4 but it is from a drw f-350 so it has the extended hubs on it. Is it possoble to use my spindles and brakes from the dana 50 TTB or will they not work. Just trying to get everything ready so it is a painless as possible. Thanks for the help
Old Nov 25, 2006 | 05:56 PM
mrwake's Avatar
mrwake
From what I understand everything from the front end of a 350 bolts up to a 250. New u bolts and sway bar are needed but thats it.
Old Dec 3, 2006 | 01:09 AM
qwik88's Avatar
qwik88
you will need to swap out the rotors so u dont have the exstentions on it
Old Dec 3, 2006 | 04:06 PM
mrwake's Avatar
mrwake
What do you mean extensions
Old Dec 3, 2006 | 04:48 PM
qwik88's Avatar
qwik88
the parts that are connected to the rotors to make it wider
Old Dec 3, 2006 | 10:28 PM
7DF250's Avatar
7DF250
Should be plentiful in wrecking yards,the "hat" for a dually sticks out alot more than a SRW hub what year D60 is it? 4X4 dually is only in a super duty pre 97 were aftermarket.
