front end vibration
Old Nov 25, 2006 | 03:30 PM
CounterMaker's Avatar
CounterMaker
front end vibration
this is my first post here but a buddy of mine has a 97 explorer 5.0 and at around 35-40 mph he says he is getting a vibration that is comparable to running over those warning strips right before a set of railroad tracks...i went for a ride with him and of course i didnt fel anything but he claims it happens all the time...he wants to keep it but he says if its something serious he is just going to get rid of it because he is leaving for the airforce soon...any ideas what it could be??o yeah the explorer has 76000 miles and is AWD
Old Nov 25, 2006 | 03:53 PM
marragtop's Avatar
marragtop
I'd start by rotating the tires front to back and see if there is any difference. If so, it could be wheel balance or tread wear problem. If he recently rotated the tires and the problem started, then I would suspect the wheels/tires. Start with the simple stuff.
Old Nov 25, 2006 | 03:56 PM
CounterMaker
well he recentley took off the passenger side front tire and replaced it with his spare because the old one was extremely bad...so the front 2 now do not match
Old Nov 25, 2006 | 04:28 PM
1081's Avatar
1081
The spare could certainly be bad. If it is the original it has been under the truck rotting for 10 years. Have him move it to the back and see if the problem goes away. Unless he really wants to get away with it, no matter what the problem is I doubt it is worth getting rid of over it. If the matching tire that was taken off was bad, it the remaining one on the driver's side just as bad too?
Old Nov 25, 2006 | 04:46 PM
CounterMaker
he said its been happening well before he put on the spare...i personally think its it his head but he claims it get pretty bad
Old Nov 25, 2006 | 07:09 PM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
Could be the front driveshaft.. I've seen several go bad... at the rear joint which is a CV type of joint.. it tends to bind up at times causing this same exact problem.
Most commonly a problem with the AWD
Old Nov 30, 2006 | 03:23 PM
caseys's Avatar
caseys
Your buddy ain't going nuts. I have a 96 Explorer 5.0 AWD with about 130k miles that has been doing the same thing. Not the tires since I have rotated as well as swapped in the winter with snow tires mounted on their own rims...and still the same problem. Does not happen all the time, only occasionally and not predictable. Just like running over warning strips or a cattle guard...
Gonna have to take a look at the front driveshaft. Thanks, Casey
