Another thing, is you're not going to want to take any off the floor. the only thing you want to do to the floor is take out any casting flash, and smooth it out, and like someone earlier said, make the short turn(the curve where the floor of the port meets the valve seat) a little less sharp, so it's not an aburubt turn, but DO NOT get carried away, just do a little.
Another way to gain alot is if you're looked into the port down through from the combustion chamber into the round hole where the vlave is, you see the vlave guide down in there. you'll notice that it's as if there are 2 troughs or gully like sections to the right and the left or the guide, that a finger can't even reach the bottom. well a tight trough like that hurts flow. make those gullies go from a tight "V" like shape, to a muss less sharp "U", or even better if the tops of that "U" go outwards!. you can also gasket match. on the exhaust side though, make the port on the head slightly smaller than the port on the headers. on the Intake you can make them the same. On the Combustion chamber put the head on the motor, and put your hand through the cylinder bore, and trace EXACTLY where the edges of the bore is compared to the head. now where the curve of the Combustion chamber is close to the cylinder bore curve, you can cut away right to that line you scribed. If you use Dykem Die, or a marker, and scribe though the die, the lines will show up, and be real easy to see.
Also, on the bottom of exhaust port, on the inside of the turn, there is a raised section, you can take some of that out, but not more than an 1/8" or so, and try to take a good bit out of the roof of the exhaust port. you can feel w/ your fingers how thick is is, because the other side isn't water, it's the outside of the head!, if you have any question, and have a couple FE heads cut up. some C8AE's, and a D2TE's.....even thought they are the same!...lol
Could you post some pictures when possible with this post? I was kind of lost as what really needs porting. I plan on re building another engine sometime soon, with some good heads for Porting and these pictures would really help us all, if possible?
well I don't have any pics right now....and not really any way to put any online....but I'll work on that for ya guys.....when I get back from PA I can probly have some online
alright nevermind, I found out I do have a digital camera....so maybe tomorrow guys, before I leave to PA!
hey, guys I don't know how to put images on a post, but I got some pix on my computer now, could someone explain how to get them on a post?, or should I just put them in my gallery?
Alright, I just put the pictures in my gallery, if anyone wants to see em'
Sorry I can't help U to explain the short turn radius thing. I'm sure someone can find you a picture. the only head I have cut up to see that in, was a 302 head, and it would be pointless for me to show it, because actually the short turn on those heads is already pretty nice. it's the long turn on those heads that suck!...lol
Now, there are a lot of little things that I did, and little concepts that helped those heads out alot, but that's my secret!, I can't give it all away, or I loose my edge!
