Air Hissing
Old Nov 25, 2006 | 02:36 PM
michael.biasi's Avatar
michael.biasi
Air Hissing
when i turnthe heat on i get a hissing from inside the cabin i assume behind the dash with a noticed loss of power
if i hit the go pedal it stops till the truck stops pulling then the hissing begins again when i get off the pedal it goes away again the hissing only happens when the heater control on the dash is engaged
so going on this and what i know of cars/trucks and vacuum actuated devices there is a leak
but im thinking that diesels dont create vacuum or do they ?? as a oldsmobile i used to have used the power steering pump to create the power assist for the brakes to work
well any way is this a know issue ?
love these cold weather maladys
mike
Old Nov 25, 2006 | 02:42 PM
Uzumati's Avatar
Uzumati
That is the EBPV activating. Tap on the brake will also make it stop. It helps the engine warm up faster.
Old Nov 25, 2006 | 02:48 PM
michael.biasi
the problem is that it never stops
Old Nov 25, 2006 | 03:02 PM
Uzumati's Avatar
Uzumati
Sounds like it is stuck
1. EBPV valve is stuck
1.5 EBPV solenoid is bad or unpluged
Old Nov 25, 2006 | 03:52 PM
spikebee's Avatar
spikebee
You could also have a bad engine oil temp sensor or a bad thermostat causing those issues. The EBPV is supposed to be disabled one the engine oil temperature reaches 167 degrees.
Old Nov 26, 2006 | 01:01 AM
Lance_I's Avatar
Lance_I
As Alan said it sounds like the ebpv is stuck or the actuator rod has came loose. Mine use to do that even when it was warm outside. I gutted mine so no problems now. Reach under there and make sure the clip is holding the rod on the actuator.
